1 - 20 of 36 Posts
I have one sitting in the Garage.
There is no BOM number on the tube so I am sure it is a custom axle (came out of a Van conversion)
Anyone else know of such a odd ainmal?
No Tag, I have not checked the ringear
I'll get pics tonight.
Yeah, All 8 lug front axles are D60HD's :shaking:
Let me put it to you this way.
The center section looks like this.
And it says D60HD on it.
(these pics were stolen from Jack Rices website, they are not actual pictures of the axle I have, if you want real pics you will have to wait till I get home)
Well this is the Gen4x forum of Pirate, just thought I'd ask :flipoff2:
Sounds like a low production quasi-custom unit made by a 4x4 van converter. I don't think there were ever any D60HD fronts made. Not that it really matters, the housing just has extra webbing and I haven't seen too many housings break.
the housing may be stronger than a regular 60 housing, but the reverse-cut
gearing for front use is still stronger for that application....... this seems like
unneeded extra weight............
--Sherpa
Discussion Starter · #10 ·
renolaw said:
i respectfully disagree-- my D44 is 8 lug.
mb
You'r kidding me???
D44's came 8 lug???
It is a low pinion DS drop Front D60HD with Ford knuckles...
And like I said, it came out of a conversion van.
A fellow club member, BadAZyj here on the board, just broke his Ford HP60 centersection. I know of another guy that broke one last October too. We might be alittle rougher on parts here in AZ though.:evil:
Discussion Starter · #13 ·
Jason M said:
renolaw said:
You'r kidding me???
D44's came 8 lug???
I'm guessing a 1976-1977 Ford axle. They were Low Pinion.
What size U-joints? Does it have the Larger inner knuckles?
The only info I have is for Dana 44 in Con Vans, but I know there were Dana 60's sold to companies doing this.
Get me some pics, and double check for that BOM, any part of it. (All Dana axle have a BOM, lets see what left after the rust got it)
this is gonna get installed in a new rig, but the owner is notorious for breaking previously unbroken parts....
Measure the size of the U-joint, that will tell a lot.
The 76-77 LP Ford runs a 5-86x joint and thus the same size as a 760 but with outer snap rings.
SO you could Run the following U-Joint
(Minnesota guy's are hard on parts also)
1 - 20 of 36 Posts
