1 - 6 of 6 Posts
Originally posted by xextr3m3:
<STRONG>how much would it cost to modify a solid axle drive shaft???</STRONG>
The only solid axle drive shaft that would work is the 84 or 85. Stay away from the 79-83 shafts, they are much weaker. YOu will need to call jess for a price but it's a little less then the IFS shaft swap because the CV allready has the desired angle. You will still need to retube it and replace the slip spline.
Originally posted by Chris Geiger:
<STRONG>
The only solid axle drive shaft that would work is the 84 or 85. Stay away from the 79-83 shafts, they are much weaker. YOu will need to call jess for a price but it's a little less then the IFS shaft swap because the CV allready has the desired angle. You will still need to retube it and replace the slip spline.</STRONG>
Cna places that retube shafts usually add more slip spline? Or do you have to buy a new slip spline somewhere?
Wicked Raciest !
Originally posted by 85MudYoTa:
<STRONG>Cna places that retube shafts usually add more slip spline? Or do you have to buy a new slip spline somewhere?</STRONG>
If they are any kind of D-Shaft place the will have or can get the long slip. I had mine made at Driveline Service of Sacramento. 84 CV and a Spicer 12" long slip for $275.00. If I were to do it all over I would make a square D-shaft, much cheaper (about $30.00 worth of steel) because all I do in 4 wheel drive is rockcrawl, no high speed driving.
1 - 6 of 6 Posts
