1 - 5 of 5 Posts
alright, we are trying to pull the hub off to do heel bearings...blah blah...anyway the snapring on the axle evidently spun and fucked up the splines around it..therfore we cant pull the rest of the hub out cause it gets hung up. Anybody else had this problem or have an easy fix?....help would be appreciated
mine did the same thing
i took a piece of strap bent in a U shape and welded it to the hub
and slide hammered it out
then spent some time with a small file and fixed the splines
if it is the splines outboard of the snap ring -they dont do anything you can make em go away. just save some material to hold the ring. if in board of the ring -then the hublock is probly in the way and you got me. you could reach around and push the shaft out as far as possable and do some time consuming file work. i can't remember if you can break the hublock down from there or not. might be a retainer for the inner splined cog -if so you could take the outer part of the hublock off?ish
1 - 5 of 5 Posts
