Both frames should be 34" outside.
Transfer the brackets with the 76 springs.
Otherwise start fabbin.
you will never get an answer on this forum for that. imho, You would be far better off looking for the answer on a corn husker site or even a dedicated Scout site. You are far more likely to come across a group (3-4) of people that might have actually worked on one or owned one.make different front drive axle spring hangers for different 4wd Loadstars (or any other truck brand) that will interchange?
Have you checked to make sure the steering boxes are the same? Just to give an example, on some 1970s Ford F-100s, the steering boxes for 2x4s and 4x4s were 180 degrees opposite each other concerning the pitman arm.Loadstar front drive axles have their spring hangers to the side of the frame, not under the frame like 2wd Loadstar's
Just because you have more leaves or thickness in the pack, does not mean it was a drastic increase in weight capacity. Any S-1700 is going to have a limited weight capacity, it is why they are 1700s, you are not going to find one with a GVWR of 33.000+ pounds. The thicker pack was probably so the axle would not submarine under torque. Your 1969 might not have power steering, your 1976 might. The thicker packs might have been needed to compensate for negative road characteristics at speed.And a 12 stack of springs seems so overkill for the front, especially considering my 2wd Loadstar only has 6 front leaf springs 3 in wide mounted under the frame.
Pictures would have been nice, at least to gawk at. Especially the interior and dash.I have a nice '69 Loadstar 1700, no rust with only 15k original miles.
It's not the springs I need, I just need the spring hangers that attach on the side of the frame, and not the common 2wd under-the-frame Loadstar spring hangers.What’s the longest spring you can use? The one we had in our shop went home a few months ago.
I suspect you are correct. Probably nobody knows the difference between a spring hanger made for a regular frame and one made for a reinforced frame using the same axle assembly. Perhaps the mounting holes are slightly different, although I doubt that because back then IH drilled all their frame rails to be used as either 2wd or 4wd. I converted a '62 IH pickup to 4wd and the frame was factory drilled for the transfer case cross member.No mdt mfg makes any of the trucks in 4wd, they are aftermarket converted.
Dollars to donuts those frames are the same outside width. Transfer the brackets as i said.
The older trucks (not talking light trucks such as F-series) I have seen with a "reinforced" frame were literally double framed with a smaller channel inside the stock frame. They probably used shipping channel. I doubt many OEM's bent their own channel and formed it. So, if you measured the back of the frame the web would be 1/2"+ with one channel nested inside the other. With stickers plastered all over it saying "do not drill or weld flange". A truck with two frames is going to weigh much more then a single frame, so, I imagine the springs and hangers have to account for it.So perhaps the hangers are just more heavy duty for a truck with a reinforced frame.
Especially if the hanger is located outside the frame instead of under it. If you measure the shackle straps/side plates, they are probably much thicker on the 4x4.Loadstar front drive axles have their spring hangers to the side of the frame, not under the frame like 2wd Loadstar's.
