1 - 9 of 9 Posts
i finally got aff my lazy butt after my buddies said they wouldnt wheel with me unless i fixed all the leaks <IMG SRC="smilies/biggrin.gif" border="0">
the front crankshaft pulley has been wobblin, but i just thought it was bent a little. the leak finally got outta control last night(steady stream) and i have now discovered it is that seal behind the pulley. i havent torn into it yet, but the reason it was wobblin is because the pulley was only supported by the belts, there was nothing bolting it to the crankshaft!!!!! <IMG SRC="smilies/rolleyes.gif" border="0">
has anyone had this happen and had the woodruff key or its spot on the crank, or crankshaft front(seal area) damaged from this??? i have my fingers crossed that a new seal and the bolted on pulley will fix...
I just changed mine because of a wobble too, but not the same one you have. Mine was seperating from the rubber part. You could possibly have some damage but you won't know until you get it apart. (and thanks for reminding me I still have to tighten that big bolt!) <IMG SRC="smilies/eyemouth.gif" border="0">
HAHA Just got done changing one today on the 94... Hey if you have any Questions about it e-mail me...
Originally posted by *mOuNtAiN gOaT*:
<STRONG>i finally got aff my lazy butt after my buddies said they wouldnt wheel with me unless i fixed all the leaks <IMG SRC="smilies/biggrin.gif" border="0">
has anyone had this happen and had the woodruff key or its spot on the crank, or crankshaft front(seal area) damaged from this??? i have my fingers crossed that a new seal and the bolted on pulley will fix...</STRONG>
the crank is somewhat gouged around the slot for the woodruff key!! <IMG SRC="smilies/crybaby2.gif" border="0"> <IMG SRC="smilies/crybaby2.gif" border="0"> as is the slot on the pulley...check your nuts and bolts!!!!!!!!im gonna buy a new pulley, nut, woodruff key and seal and hope for the best... <IMG SRC="smilies/frown.gif" border="0"> <IMG SRC="smilies/frown.gif" border="0">
Does yer dewg bite?
Dude, you need to check all your nuts (including the ones in you pants) <IMG SRC="smilies/eek.gif" border="0">
I think your truck is coming undone <IMG SRC="smilies/thefinger.gif" border="0">
I check all the nuts and bolts after every trip. Well, not all, but most (U-bolts, steering, wheels, ect.)
Good luck! Hope you stuff works <IMG SRC="smilies/smile.gif" border="0">
<IMG SRC="smilies/usa.gif" border="0"> <IMG SRC="smilies/usa.gif" border="0">
Hopefully you can salvage whats left to the crankshaft and it wont vibrate your engine to pieces. Good luck <IMG SRC="smilies/eek.gif" border="0">
Discussion Starter · #9 ·
Originally posted by Vova:
<STRONG>Dude, you need to check all your nuts (including the ones in you pants) <IMG SRC="smilies/eek.gif" border="0">
<IMG SRC="smilies/usa.gif" border="0"> <IMG SRC="smilies/usa.gif" border="0"></STRONG>
the engine and under the hood is sooo clean you could eat off it now. vova youd be proud!!!!!!
<IMG SRC="smilies/smokin.gif" border="0"> <IMG SRC="smilies/smokin.gif" border="0">
1 - 9 of 9 Posts
