so, got to replace the front bearings and wondered about following specs on the torque for the two big nuts with larger than stock tires..
FSM says preload at 46# then back off to 18 which seemed a little loose for 35x13" tires and the outer nut at 33#.
I did one side to specs and test drove and things loosened up in a few miles on the hwy...front wobble...got home and both nuts barely had any torque.
so...what is the recommendation for torque on these suckers so I don't have to worry about tightening them up ever 100 miles?
'00 Tacoma, Diamond SA up front with Yota outers.
