1 - 1 of 1 Posts
FS:88' Cherokee $700.00
I bought the jeep to make as a trail rig so I never had it inspected or registered. Hasn't had both since 2005.
It has got to go. So someone please buy it. $700.00
It is a 1988 Cherokee Laredo
Automatic
4.0L
231 T-Case
246,000 miles
4x4
4 Door
Located in Lubbock, TX.
New:
Battery
All battery cable
Distributor, cap, rotor
Spark plug wires & Plugs
CPS (crankshaft positioner sensor)
Fuel pressure regulator
Fuel Filter
Fuel Pump
Updated Radiator from a 93'
Coolant Reservoir Bottle
All major Hoses
New ECM
Front Brakes
Front Right Amber turn signal housing
Stuff I changed:
Relocated the gas tank
No back seat
No Headliner
No carpet from behind the front seats to the rear. Wanted to make sure there was no rust and then decided to keep it out.
Dash was a bit apart when I bought it. Can put it back together.
A/C is not hooked up
Mods:
2.25 budget boost lift. Spacers up front with shackles in the rear and Air shocks (on it when I bought it)
Bad:
Front pinion gear is toast
Right Rear tail light housing is broke
Carpet and seats could use a good cleaning
Extras:
D30 axle shafts
Pictures here:
http://s174.photobucket.com/albums/w85/Abstrastic/Jeep/
1 - 1 of 1 Posts
