1 - 5 of 5 Posts
Part #10007
Never used, only taken out of the box to check out parts. Never been connected and nothing cut. So what Im saying is that it is BRAND NEW.
Retails for 399.95 (check it on Google)
Asking $325.00, I will ship at whatever the rate is. In 92688 so you can check shipping charges and choose how you want it. Or pick up is cool with me if your close enough.
Info:
Constant Duty Onboard Air System
(P/N: 10007)
(1) 2.5 Gallon Viair Air Tank
(1) 450C model Viair Air Compressor
(1) 35ft. Coil Hose
(1) 1/4" Quick Connect Stud (F)
(1) 1/4" NPT Quick Connect Coupler (F)
(1) Dash Panel Gauge with ON/OFF Switch
(1) Pressure Switch with Relay (110 PSI on, 150 PSI off)
(1) Reducer (1/8" NPT F to 1/4" NPT M)
(1) 1/4" NPT 175 PSI Safety Valve
(1) 1/4" Drain Cock
(3) 1/4" NPT Compression Fittings
(1) 4-inch Strip of Continuous Grommet Material
(1) 20ft. 12 Gauge Wire with Inline Fuse Holder
450C Tire Inflation Rates
Begin/End PSI 31" X 10.5"
0 To 30 PSI 4 Min. 05 Sec.
15 To 30 PSI 2 Min. 10 Sec.
Begin/End PSI 33" X 12.5"
0 To 30 PSI 5 Min. 30 Sec.
15 To 30 PSI 2 Min. 50 Sec.
Begin/End PSI 35" X 12.5"
0 To 30 PSI 6 Min. 55 Sec.
15 To 30 PSI 3 Min. 30 Sec.
Discussion Starter · #2 ·
Bump...
I know I am not a active user on this board, but I figured I would get the most interest out of this forum as there is the broadest spectrum of offroaders here.
I am a TTORA member, as well as a few other boards.
· Premium Member
I know this has the on/off switch, but does it deflate from in the cab? ie if you were using airbaigs and needed to deflate them?
this kit does not come with an electrical dump switch. It does have a manual dump valve that could be plumbed the the gauge area that you could use to dump air as to the porportion you wanted.
Im sure that there is something that you could integrate into this that would accomplish that.
thanks for your interest
1 - 5 of 5 Posts
