1 - 9 of 9 Posts
After my truck gets warm, I begin to smell gas while driving down the road and whenever I put the truck in a torque intensive position it chokes out. Do I just need to adjust the carb, could I have water in my distributor cap, etc.......?????
Start by checking all the rubber lines in the fuel system for cracks and leaks. It also sounds like the carb needs to be adjusted or rebuilt, check the float and make sure it's not full of gas. Which carb is it?
It sounds like your float is overflowing... This can be caused by either too much fuel pressure or your needle valve leaking. When you smell the gas, open the hood and look around the engine for any wet spots that might be gas. If it's from your carb, your truck will probaly run better once the problem is fixed
Yeah, but it's done that since I got the truck and I wasn't having problems until recently
What could that have to do with the prob?
RIP Angel
I have a 76, had the same problem. Found a small gas leak in a 6" piece of tubing under the pass door. Replaced it. Needle stopped dancing prob. appears to be solved. Needle danced along time before prob started for me too. I think its from pressure being lost from the crack!!
I snickered when I read this. Said thats it! PM me if u want to go into greater detail. Besides its a cheap place to start. :D
That's crazy, I just replace a little rubber piece under the pass. door and I bet it's not properly sealed. I'll check it out and get back with you. Pirate comes through again :)
1 - 9 of 9 Posts
