Carter p611396 02c18a
I got this at Oriely,s it said SW on the box but was reboxed from factory, remember the thing has american fitting, you might find something if you are in a bigger town, one thing you can do with the gas tanks is buy 2 used bottom tank drain plugs and drill them out and armor a fuel bowl like on a welding machine gas tank so both are connected, i ran ball bearings in both tanks for a long time and still get rust coming out sometimes after 5,000 miles, my truck sat with water in tanks too, stainless is nice, all one compartment and one drain and ONE fuelline, what were these guys thinking with the crappy set up? good luck! Could not find a regulator, i got pissed and put it all back to stock, the regulaor I looked at was a Holley ands like waytoHIGH so I just grabbed both cheecks for UPS, what can you do? The regulaor and pump is more than the stock set up! You can buy a stainless tank for $200 same size as stock, forgot who has them but i think 2 or 3 dealers, some just get a 406 diesel used tank it is bigger and fits but same old waytohigh usually!
