1 - 20 of 63 Posts
OK, "Werd" on the street is that the Full Traction Long Arm kit is the best on the market right now.
Is Rubicon Express planning on improving their long arm kit?
I talked to Larry at mad4wd.com today and he says that even though he runs the RE 5.5 he thinks the Full Traction 6" Long Arm Kit is better
is every way possible.
What do you guys think? Now is time for your 2¢
Tough call. I have a friend that put in the Full Traction kit in his TJ and swears by it. Looks like a nice kit and well designed but the R.E. kit has been more than proven. This might be a more interesting question with more answers after a year or two ya know?
302YJ said:
Is Rubicon Express planning on improving their long arm kit?...
I doubt RE is going to improve on anything. They have known issues on their LA kit, that they refuse to fix. (Like bolt holes that are not big enough for the bolts they provide.) They know about these problems, but ship them every day with the same shit. :mad3:
That being said, other than relatively small problems in the initial install, the lift works great. Just don't think RE is improving anything, when they ship shit that they know is fawked up.
:flipoff2:
What vehicle lift are you asking about? TJ, XJ? I can vouch for the XJ long arm lift. I got one of the first batch runs earlier this year, and I really like it. It rides better than both of my other two stock XJ's on the street, and works really well on the trail. I've run Fordyce, the Rubicon twice and partially on the clean-up, and been to Hollister Hills a ton of times. The components are top-notch and the welding is really nice. Fit and finish was suprisingly accurate and consistent. My only complaints are:
1) No matter how hard I tried, the track bar mounting bracket that attaches to the frame would not stay tight. I tried different bolts, tightening it in different sequences, etc. I finally just welded it and haven't had a problem since.
2) The lock nuts that they provide with the kit are garbage. RE uses the same ones, and they just bugger up the threads too much if you need to back them out to realign or adjust something. I switched most of them out with nylock nuts before installation and was happy that I did later - especially on the u-bolts.
3) The instructions suck. If you're not mechanically minded or know how the suspension works-forget it. I didn't have any trouble installing it, but there were times when I wished they went into further detail-especially on the arm length adjustments when the install was complete.
Overall it's a great kit. I've see photos of RE's new long arm kit for the XJ's and it doesn't look like it will come close to FT's. BUT, that's my opinion based off of pictures, it might change if I see it out on the trail.
Here's a good underside shot:
The arms make decent rock sliders too:
This is my DD also. I'm suprised at how smooth it is on the street.
i guess i should have said that i was talking about the TJ kit. From what i hear the quality of the kit is much higher. The welds are better and it just seems to be made out of better materials.
Of course, there is the off set in the differences in prices. I usually see the RE kit for under $2,000 where as the cheapest i've seen the FT kit is somewhere around $2,295
The install of the RE kit requires a good welding, whereas the FT kit is bolt on BUT requires a completely new ehaust set up.
The RE problems have all been well documented throughtout all the years, what problems are people running into with the FT kit?
What was a typical install time with the FT kit?
I would need to know so i didn't tie up a bay at the shop for too long.
thanks.
btw, the XJ kit looks good too!
We are installing them in about 2 days. We work on them over two days and make sure evrything is dialed in on day 2. The first one took a lot longer. We quit trying to drill holes in the frame to mount the cross member and just weld them in now.
Mark S
thanks.
RE doesn't require welding.
Ask this at JU
:flipoff2:
Full Traction kit is much better.
The RE kit uses a radius arm style suspension which cannot compare to the 4-link features on the FT kit. By using proper geometry on the front suspension FT was able to make a proper caster curve. This makes the vehicle drive much better. Also the rear of the FT kit is triangulates while the RE kit keeps the trac bar. This makes for better stability and increase wheel travel.
I'm getting close to doing a lift on my POS so find this thread of great interest. I've actually narrowed my choices down between Rubicon Express and Full Traction but also have been waiting to hear some opinions. I do know of one person on another board that wheels with the FT setup and swears by it. It seems to me there is some good engineering reasons for the triangulated rear but what about wear on the high mis-alignment uni-ball joint? Anyone know how well this will hold up? At least it's rebuildable. So far, there's been a lot of second-hand opinions...anyone actually run this setup?
-Phil, the Newbie-fawker.
I'm running the TJ FT kit. The only problem I've run into is bending 2 of the tri-link brackets where the rear upper wishbone mounts to. It has since been redesigned with some reinforcing brackets. I ended up just welding a truss to my rear axle for the tri-link, works fine. The high misalignment uniball is working well after a year and a half as well. As you can see, the ass drops out pretty good in the rear.
Dork in the box on the Rubicon
1 - 20 of 63 Posts
