1 - 12 of 12 Posts
i've been pondering upgrading to high pinion fz80 3rd's in my fj40 for better clearance, driveline angle, and supposedly stronger? and was just checking this out on marlin crawler, they have empty fz80 3rd housing's for $265 just wondering if anyone knows will the fz80 3rd housing use all my fj40 diff parts? i've already got detroits and don't want to start all over again you know? http://www.marlincrawler.com/3rd_cruiser.html
so the front of an 80 has a mini sized third but has huge birf's ? or am I missing something. is it possible to put the ends off an 80 axle onto a fj40 housing and then use the 80 birf's , knuckles , brakes , etc. ???????
There is no way that the 8" HP could live in your rear axle, and I saw one HP destroy the stock spider carrier completely in Moab a few years ago in a front axle only turning 35s.
Others can go more indepth, but it's rather hard to graph the 80 knuckles onto the 40/55/60 housing. Steeting solutions get to be $$$ aswell, since the tierod bolts to the bottom of the knuckle.
peesalot said:
does noone know thw damn answer , cmon , I know the length is different but can't you just get custon inners or are the 80 birf's totally different spline than mini's and 40's.
Damn newbies! Search! :flipoff2:
http://www.pirate4x4.com/forum/showthread.php?t=241557&highlight=80+series+birfs
http://www.pirate4x4.com/forum/showthread.php?t=219318&highlight=80+series+birfs
I believe the inners are 27 spline as well. If Bobby extends his new line of 30 spline, I don't see any reason why you couldn't have larger 30 spline 80 axles.
QUOTE]
But that was also on a truck that had already broke the rear and a truck that was probably pushing the 7k lb mark climbing on a steep hill with ample traction to the tires.
Anything is possible. How much time and money do you want to spend? 80 series birfs are huge compared to even 60/mini birfs. You wouldn't be able to fit them with grinding. The easiest way to do this is to convert to mini truck axles and toss in the 80 series thirds.
An 8" HP diff will NOT survive in the back of anything over 2K lbs and with more than 20HP. Marlin tried it a number of times and they simply don't work. We're not talking about a D-60 here... Up front? Yup. Rear? Nope.
And Yeti is right - they won't fit a 40/60 housing.
Dude, we need to get you a cruiser. You seem to keep popping up with all these cruiser links, now showing up in the cruiser section. It's fate!
1 - 12 of 12 Posts
