1 - 10 of 10 Posts
Hey I am looking at swapping in a rear elocked fzj80 axle into my 2002 tacoma. My tacoma currently has an elocker, is it just a plug and play type of deal for the cruiser axle to get that locker to work? I don't have the axle yet, just trying to plan ahead.
There is a good chance it is plug and play, there is a chance however that they used a different style plug. When you get the fj80 axle, look at the 2 plugs and i they are the same you will be fine.
if the plugs don't match, look into what wires do what and how many. the taco has one 5 wire plug, the motor, and one 2 wire plug, lock position sensor. likely that the 2 wire connector would be the same. if the 5 wire plug isn't the same, but both are 5 wire, you could just re-pin the cruiser plug/wires into the taco connector.
Jsyk- avoid snapping a shaft in those elocked rears. Usually requires surgery to remove
That's generally my goal when wheeling, to not snap a shaft on either end. Even if you have a 14bolt or any other axle its a pain the ass to remove a snapped shaft and usually requires major surgery to remove all the broken parts....
Like cutting open the housing kind of surgery ;)
It usually snaps and you can't remove the 3rd or get the chunk of shaft out from the end.
1 - 10 of 10 Posts
