1 - 8 of 8 Posts
I'm cleaning out my garage and have the flopping stuff for sale. I'm located in Clarksville, TN. Call or text at 931-4seventwo-9two7nine. Pics can be seen here Jk 4 inch lift with 35 inch MTZs, Gas tank and PSC assist ram
and here Garage Cleanout: Jeep Stuff, 14 Bolt Axle, Dana 60 Front, and more....
The poor man's jeep jk lift kit. I'm putting 43 inch tires on my jeep so I'm selling my 4 inch lift kit and 34 inch tires. I've got 4 Mickey Thompson MTZ tires with about half and inch of tread on them, 5 pro comp extreme wheels in the jk 5 x 5 wheel pattern, all the brackets and springs from my 4 inch lift kit, and two front bilstein shocks. I've got a 5th tire with a cut in the sidewall that I'm throwing in for free. The cut can be vulcanized at a tractor tire shop pretty cheap and used for an off road spare. I'm asking 700 for the tires and 120 for the lift. TIRES ARE SOLD
14 bolt DRW first gen axle. Its currently disassembled and I have all the parts to complete it. It's ready for a disk brake conversion or a regear. $100 for everything. I am willing to part it out if someone wants the housing for a 14 front, axle shafts, or hubs.
99-04 Ford Dana 60 front axle. This is just the housing only. No knuckles. I still have the long side axle shaft, 3.73 ring and pinion, and carrier. $60 SOLD
Miller Spectrum 125c plasma cutter. Runs and cuts great. $300. SOLD
PSC hydro assist ram from a 07 Jeep Wrangler JK Kit. 1.75 with a 6.75" stroke. $90.
I've also got the JK stock steering box with -6 AN taps for the ram. The steering box probably needs a rebuild though. The rebuilt kit is around 40 bucks from ******* ram hydraulic steering assist. $30 for the steering box. SOLD
E99 7.3 Powerstroke Spider. This is used to install an intercooler in your 94-99 7.3 Powerstoke Truck. It has the same diameter opening as the intake manifold on each of the cylinder heads. It bolts right up to the turbo and cylinder heads. These are hard to find. $100. I can also tell you where to get a used 6.0 intercooler for a 100 bucks for your intercooler install. SOLD
2007 Jeep Wrangler JK stock fuel tank and skid plate. $200 Two door black stock carpet $100. Front seats $70 for the pair. I've also got a bunch of other stock parts: Brake booster, engine wiring harness, ESP brake module, plastic engine compartment mounts that the battery and ecu sit on, ecu, radiator.
Autometer ultra lite pyrometer egt gauge new in box $120.
Autometer ultra lite volts gauge new in box $30.
About 80 ft of 1/0 THWN southbend cable. $50.
Carlin 201 waste oil burner. This burner can be used to burn waste motor oil to heat your home or business. I was going to use it to heat my garage but I have too many projects and don't think I will be able to get to it. It is brand new out of the box. $300.
I keep forgetting to check my post. Sorry. The dana 60 is sold, the steering box is sold, and the 14 bolt has 3.73 gears. Knucklehead contact me on my phone for pics of the ram. The quickest way to get a hold of me is at my cell 931-47two-9two79.
1 - 8 of 8 Posts
