1 - 9 of 9 Posts
Ok so if anyone can help it will be this site.
Back story: I have only done a few dozen axle set-ups so I'm by no means even close to an expert. With that being said I took on a job from a guy that had his 10.5" rear out of a 2008 1500 re-geared 3 times by the same guy and they were destroyed within 500 miles with correct break-in procedure done. It came to me apart so i had no real starting point for pinion depth. I started with .030 and went from there until I got a good pattern centered from flank to face with .006 backlash.
FF to today: It lasted about 1200 miles with same issue. Ran a new pattern and now it is barely touching the drive side toe and way toward the face of the coast side. when i ran the new pattern i noticed that there was resistance at 3/4 revolution of the ring gear. I took off the ring gear, reinstalled the locker, and ran a gauge on the mounting face. it appears to be out .004" in spots as I rotate it.
Would this cause the gears to wear this fast? Does any of this make sense. I have pics and video that I can post from my phone if that helps.
THANKS ahead of time.
Never heard of such. I don't understand. Are you saying the carrier surface is .040" out of round or .040" out left and right? Are you checking the pattern in three locations?
I would say there's something wrong with you setup on the .040" . I just don't see how it could run at all.
I'm about as experienced as you, so not gospel. But I would guess the problem is in the preloads. (Either pinion or carrier) Did either of them appear loose?
Umm, that's .004", not .040". Big differnce. Not saying .004" is nothing, but .040" is incredible.
I would think that should be less than one thou. I have a loose carrier I can check tomorrow. Just thinking out loud, if you had 6 thou BL, it would go to 2 thou every revolution. Sounds like trouble. When you checked back lash, did you check it a few places around? It really should be the same, but I always check it around. (Just like the pattern)
Edit , my comment about it going to 2 thou is not correct. Not sure how much it would effect it.
1 - 9 of 9 Posts
