Thought I ought to start one of these new-fangled build threads to document GIJeepN's transformation from mild-wheeler to.... well something else. lol
The plan is to give GIJeepN (my 1997 Jeep Wrangler Sport) some much needed upgrades and breathe some new life into her.
This includes:
Dana 60 front from a 2008 F350 w/ 5.38:1 gears and an ARB Air Locker 10.5"
Rear from a 2009 F350 w/ 5.38:1 gears and either a Detroit or ARB Locker
Fox 2.5" 14" Air Shocks
Klune-V under drive unit with 2.72:1 low range
40x13.50-17 TSL/SXII Tires on ProComp wheels with Staun internal beadlocks
3-4" or more front stretch
5-7" or more rear stretch
Full Hydraulic steering
What she looks like now. 35" Mickey Thompson Baja Claw tires, Dana 30 front axle with 4.56:1 gears and an ARB Locker, Dana 44 rear axle with 4.56:1 gears with a Detroit Locker, 4.5" lift provided by ProCom springs and rough country long arm upgrade kit, 4:1 low range with slip yoke eliminator kit, York on-board air system.
Axles
Removing all the brackets from the front axle
Test fitting the truss (Artec TJ 1Ton truss kit)
Welding the truss. I used an Eastwood MIG250 with .035" solid wire and C25 mix gas for the welding of the truss to the tubes and a Lotus 200amp TIG/Stick/Plasma with the Ni99 rods and an Air Hammer for the welding to the cast.
Welding axle tubes.
I should be starting to disassemble the front end of GIJeepN and finishing up welding the brackets on the truss this weekend.
This includes:
Axles
Welding axle tubes.
