221 - 240 of 740 Posts
Discussion Starter #221
omix ada headlight retainer rings suck..they might as well be made of tinfoil. the seam/splice kinks and they look like shit basically. Nit picky I know but I put serious cash into led headlamps and I dont want them to look crappy. The TJ rings I have seen at the 4x4 shops are the same thing with the split in the ring. do quality rings exist?
I need to start thinking about exhaust. I have a pet peeve about replacing rusted out exhaust systems 2 years after install in the michigan salt.. I have a 4.3 and I will be running true dual exhaust all the way back. I plan to use stainless pipe and mufflers. My goal is for it to be so quiet I can't hear it run.
What diameter pipes should I run? I can squeak 2" past the d300 on the drivers side, a little bigger if I squeeze the pipe oblong.
What is a good,quiet, small muffler? The stock system had a resonator on it? Do I need to think about using these?
Thx for any help!
This might help. How To Calculate Muffler Size and Exhaust Pipe Diameter | Exhaust Videos
Discussion Starter #224
Thanks!
It is 14 1/2 gallons. I have a 4" pipe I need to turn threads on and I am using a vented cap from a semi truck tank. Should just weld on and using a new rubber grommet. Should look good with the grab bar placed across it. My goal is to add ten more gallons under floor in the back at some point.
Discussion Starter #225
made a little progress this weekend. I got the steering in. i used an ididit tilt column and a grant banjo wheel. I made a bracket for the dash out of 2" ID pipe and tapped it for a few set screws to hold it.
my gas tank is about 1/4" thick aluminum. if i drill and tap it to hold a ring to secure the fuel pump will the bolt holes leak gas? is teflon tape good enough to seal them or is there some other stuff I should use?
Teflon tape is generally used on tapered threads like pipe fittings.
For straight threads you want to use a tread sealant of some kind. You can find it at most parts stores. Its a white sticky gunk that comes in a tube. I used it on my transfer case rebuild and it seemed to work ok.
The big question is if it is rated for gasoline. That I don't know.
Be careful tapping the tank. Is it really THAT thick? I would stick to something around 10-24 threads or smaller. You can generally drill a slightly smaller pilot hole for the tap with aluminum for a little more thread engagement.
Are you going to have a rubber seal for the fuel pump itself? Why not extend that around the mounting holes?
You could also use some blind nut-serts for mounting holes. They wouldn't have the leak path up the threads.
McMaster-Carr
Go down to the closed end version.
I would make a bolt ring, with a slit in it. The slit will allow you to insert it into the tank. This is what I did. I did a quick search and the pics on this web page will show the bolt ring. Mine was pretty easy to build.
Aeromotive Phantom Fuel Delivery System - Car Craft Magazine
If you do try and tap the aluminum, use a spiral flute tap.
Discussion Starter #228 (Edited)
after staring at it again here is what I think i will do. Cut a flat flange out of 3/16" to go over the hat of the pump. Drill 10holes in it at a diameter just larger than the hat on the fuel pump.
Use the flange as a template to drill 10 holes in the tank is actually 3/16" thick, and tap them. I will use flange top bolts and screw up from from inside the tank. Each bolt will have a viton O ring in addition to fuel safe thread sealer inside the tapped holes. The hat itself also has a viton O ring. then clamp it all down the flange /template. The threads only have to be strong enough to compress the O rings and hold bolt in place while tightening down top flange.
Clear as mud right?
Interesting. Was there not room to stick the sump inside the frame behind the transfer case on the passenger side?
Discussion Starter #232
I also did some more work on the tunnel and got the shifters mounted. I needed to modify the trans support for the cables on the NWF transfer case shifter but it seems to work well. I was impressed how tight I could bend the cables and still have smooth , non binding movement of the cable.
Discussion Starter #233 (Edited)
there were a few reasons I didnt put it inside the frame...which was my first choice:
1. it encroached on the tunnel in the center of the tank which I made with right angles for ease of fabrication. you can see here that I could not move sump to the center far enough to get inside the frame on the passenger side.
2. it would make running exhaust pipe past the transfer case a mess on the drivers side
3 it would have chopped up the hat channels. where I put it was a clean cut between them.
4. anywhere inside the frame would have put the exhaust too close to the sump and i wasconcerned about heating that small amount of fuel at low tank levels.
I figured if the GPW can get away with that huge sump, this little 6"x6" wouldnt get in the way too bad!
If I Drill through I don't need spiral flute tap correct?
Spiral flute tap and magic tap cutting fluid, works great for taping aluminum. I would use the smallest recomended minor diameter drill bit, prior to tapping. Aluminum and steel will have different minor diameters. I would also use that minor diameter drill bit to drill your 3/16" ring as a template, after you transfer the holes you can drill them to the proper size. Also get some small bolts and nuts, so you can bolt /clamp the ring as you go.
Thread - Drill & Tap Chart
WD40 makes GREAT cutting fluid for aluminum.
Find a test piece of aluminum to prove your pilot hole size and tap on. Perfect your technique and then move onto the real thing.
A friend turned me onto power tapping smaller sizes with a variable speed drill. I did a lot of smaller 10-24 size stuff like that. It works well once you get the technique down.
Discussion Starter #238
Finally forced myself to deal with the Tranny brace being in the way of the cable Shifters. I ran some pipe through it and created a passage for the cables. It is VERY tight down there
I also put the Jerry can holder on.
Discussion Starter #240 (Edited)
Started working on the fuel filler neck for the gas tank. It is 4" like the original and I bought a piece of aluminum pipe nd had a thread cut on it.
The cap is from a semi truck diesel tank and says it is vented. It does have a Springed valve in the center but it seems to only move out to release pressure. How can I tell if it will also relieve vacuum? Just trying to figure out if I need a vent. I didn't think I did with huge 4" fill opening since air can easily escape around a gas nozzle during filling but I am concerned about vacuum cited while cap is on and engine is running.
