1 - 17 of 17 Posts
GM 6.0L LQ4 Crate Engine
Almost new. I'd wager it has less than 40hrs run time on it. It has never been installed in a vehicle.
This engine was used on a dyno for some type of testing or development.
It is mostly complete, top to bottom. It does not come with starter, flex plate, coils, wiring, or electronics, but all of the engine sensors are there, as well as the TB and intake.
This is the iron head version, which was the 99 model year.
By all inspections, this engine appears to have very little run time on it. Everything from a visual standpoint looks brand new, and it rotates smoothly. Spark plugs look great, inside the cylinders (what I can see w/flashlight) look clean, and under the valve cover all look new.
Comes with all the accessorie brackets and components, alternator and PS pump on the front of the engine with the exception of a/c pump.
See pictures here:
http://snipurl.com/1qvwx
$1000 or trade for PSD Dana 60 front, or a 203/205 doubler kit.
Smurf and Yota are indeed correct. It is the LQ4.
Somehow I mixed it up. The title has been edited to reflect.
They use flat top pistons vs the dished in the LQ4 to get the 10hp increase the LQ9 nets.
Somebody make me an offer on this thing, it really is going to make someone a VERY NICE engine.
I'd keep it if I had room to store it, and I'm beginning to contemplate selling my 327 to fund what I need to make the LQ4 work in my junk...
JS
Where are you located? exactly what do you need for your doubler setup? Are you talking the case's or just the kit to make your case's into a doubler?
If it isnt sold, I know a guy that will trade you a complete new adapter kit, new shaft and everything. PM me if you are interested.
1 - 17 of 17 Posts
