1 - 8 of 8 Posts
blatant asshole
Absolutely not.
If you get $100 im sure as shit posting mine again.
You can get new ones for a little more than $100
And i saw iron ones for as low as $130.
I'm quoting what I told you through email.
"No threads, all holes are for studs or bolts. No cracks. I simply swapped to a dodge tailhousing and dont need it anymore. It is aluminum but painted black"
I may have not been 100% clear, but I did say no threads. I did not in any way try to mislead you. I sent pictures which showed the holes.
I basically sold you a $100 part for $30 plus $20 shipping and now you want $20 back because some through holes now require longer bolts and two nuts in an easy to access location.
Ship it back to me and I'll refund your money.
You PM'd me an email to send pictures to. I then sent pictures and information and we emailed back and forth probably 10 times. You sent me money. I sent the tail housing. I don't know how you can say you never received an email from me. If there was a middle guy I was emailing and it wasn't you, that's not my fault.
Maybe I didn't mention it in the first post because I didn't remember or didn't think it was an issue. Consider it an upgrade now you can use larger bolts :)
Good luck finding another one for $50. I have a hard time believing you are going to toss this in the garbage if you have a need for one when 2 nuts will solve your issue. The 2 transmission mount holes do NOT need to be threaded.
Yes, I was going to toss it in the recycling. It worked perfect the few years I had it in my rig, then I switched to a dodge tail housing to shorten my transmission when I switched to the atlas. It's all in my build thread. I'm not lying. The $30 I made off of it was hardly worth the time I spent selling it, packaging it, and shipping. I would refund your money if I didn't think you were being a tool about it.
You have the option to ship it back or keep it. It's up to you.
Attachments containing proof of email info/phone numbers deleted per ParadiseAutoElectric request
1 - 8 of 8 Posts
