I have a NP205 round pattern transfer case with long 32 spline input shaft that I want to mate to my 1997 GM NV4500. I will be replacing the aluminum tail housing on my NV4500 with a cast iron tail housing. I am planning to use ORD twin sticks. I believe I have two options. I listed them below with details as I understand them (it is possible I don't fully understand them)
Your input, advice and experiences on this subject are welcome and will help me make a decision. Thanks for the help!
- Purchase Advance Adapters 50-69101-5/8" spacer and bolt the NV4500 to the NP205 with the spacer between them:
- Machining the NV4500 tail housing to clear the NP205 rear shifter rail IS required
- Machining the NV4500 tail housing for the idler shaft retaining nut is NOT required
- The Advance Adapters spacer is another potential leak point
- The Advance Adapters spacer cost $108
- Purchase a NP205 short 32 spline input shaft and bolt the NV4500 directly to the NP205:
- Machining the NV4500 tail housing for the idler shaft retaining nut IS required
- I've read this post that says the NP205 input bearing retainer is taller than the NV4500 tail housing register and must be machined. Can anyone confirm this?
- The NP205 short 32 spline input shaft is $120.
- No additional leak point because a spacer isn't used.
