1 - 16 of 16 Posts
Why do I hear people talking about doing this?
Are GM outters stronger? If I'm switching to GM I know that I'll need
knuckles, spindles, hubs,stubs, but what about brake caliper brackets?
Yup, thats what my axle was... Ford housing-tubes and c's and gm everything else... that is until I broke the centersection.:flipoff2:
You will need.
- Spindles
- Knuckles
- Locking Hubs or Drive Flanges
- Complete Hub Assemblys (with Rotors)
- Caliper Brackets
- Calipers (exchange your Ford ones @ Napa for Reman Ones)
- GM Outer Stub Shafts
- Spindle Nut Kits
I`m in the process of doing this on my Ford D60, Ihave all the parts just need to finish up!!
Discussion Starter #5
I've got a set of hubs, rotors, and 1 spindle that are 8 lug,
so I'm assuming that they are d60 but I guess they could
be 44... humm I think that I'll take a look at them tomorrow..
what's a set of used knuckles worth?
for a 44 or a 60?
Discussion Starter #7
Discussion Starter #8
are these dana 44 or 60? Do 8 lug chevy 44 and 60 hub and rotors
interchange?
Nothing from a 44 interchanges to a 60, unless you have conversion caliper mounts.
It's hard to tell what you have, size perspective.
My Dodge hubs are external lock-out hubs and use 8 bolts for the L/Os.
Show a picture of the knuckle they mount to.
The bottom pic has a lock-out or drive slug to the right. If that's from your parts, it's a 44 using a 19 spline stub.
Discussion Starter #10
don't have the knuckles, just got this stuff with in another deal.
redrill
Todd W said:
You will need.
- Spindles
- Knuckles
- Caliper Brackets
- Spindle Nut Kits
Couldnt he just redrill the chevy knuckles to accept ford spindle and be done with it?
By using GM stuff from the knuckle out does this also increase the WMS of the axle since the GM stuff is ~.5" longer? Effectivly increaseing the width of the axle 1" total?
Yes, .600" per side, 1.200" total width.
Assuming the 19 spline drive flange in the lower right corner of the last two pics came off the hub you are showing, that is D44 stuff.
edit: I need to read all the responses before posting. :D I just repeated what JeepinDoug had already posted.
1 - 16 of 16 Posts
