21 - 25 of 25 Posts
Discussion Starter #21
Sweet, Thanks
Yes it is My 88 Sub.
The harness is out of a 88 Sub,(Not mine)
I will test voltage at the Map sensor after work today.
i have a customer that has one - its a 85 by the vin, but says 86 on the emission sticker - i noticed it because the vaccum diagram showed an advance, then confermed when i did a tune up - only a power and tack lead out of the dizzy, with an advance - its the only one ive seen in person.
and a 88 burban with a tbi 350 - ill get you an ecm diagram - dose the map sensor have vaccum ? no leaks to it ? 5 volt, ground and signal ? ill get a few pics
Odd--the first TBI's we saw in non comercial vehicles was in 87 but we never saw the comercail stuff.
Discussion Starter #23
Found it!!
The Vaccume Hose had a Hairline crack.
Replaced it now it runs better.
I think I still have some bad fuel but, No Codes.
Thanks Allot For all the advice!!
Was it the stock plastic hose with rubber ends? Saw alot crack on the tbi side...
21 - 25 of 25 Posts
