I want to put a 2001-2004 GM ZF 6 speed manaul (found in 3/4, 1-ton 8.1L and 6.6L) in my '93 Chevy truck. From what I understand, the bellhousing is integral and matches the typical GM bellhousing bolt pattern (SB, BB, 6.5TD), correct me if I'm wrong. What I'm not sure is if the adapter will fit my '93 t-case? What t-case do the 2001-2004 3/4 and 1-tons use? Is the bolt pattern the same? How long is the ZF tranny? Any input would be GREATLY appreciated!!
Ant
Ant
