Well. .
Between yesterday after work and today after work, I was able to make a little Head way. Yesterday, All I wanted to do was get the beginning of the up pipe to bolt up to my stock manifold. So a before pic of what I had to make:
And the after pic after all is tacked up:
The O-2 Sensor will be mounted on the inside of the above bend, similar to the stock location. I also bought my O-2 Bung yesterday. that will get welded in when I remove the complete up-pipe system to do final burn in of all weld points.
So today was to bolt on the "beginnings" of my up-pipe to the manifold and start doing mock up:
Then I cut another piece to wrap in front of the oil pan:
Another view:
this is where I stopped. To mate the up pipe to the turbine flange, I needed to start work on the other end.
So this is how you make a round plug fit into a rectangle hole:
before:
then a few cuts here, some bending there, during:
So now its time to figure out how to plug up them nasty holes at the corner. So I cut some sacrificail pipe(only 3/4 of an inch) and started cuttin some plugs Here is what I got to this point:
Im ok with this set up. But I still need to alot of work and massaging to this piece. Pics of the final product will be posted soon. the remaining pipe from the flange will more then likely get trimmed off. I need to get this flange done to aid me in connecting to the up pipe. I figure start a little from one end and stop, then start at the other end and stop. do a little at a time to get the best set up.
Next step: start doing the reinforcement brackets to hold the weight of the turbo unit. then I can finish my up-pipe. And when Im happey the the up-pipe, remove and burn it all in.
