Ok, after work today I got a little bit done. This is how you make a round peg fit into a square hole. I started on the up pipe flange and did some more massaging and this is what I ended up with:
I went ahead and removed the excess piping from this after I was done to aid in the most room needed to run a bend up into this.
So after that, I needed to work on bracketry. I need to hardmount this turbo before I can continue on the up pipe. this part of the work Kicked my butt. So I mounted the flange and my first piece of brackets:
And I rigged up another bracket off of the stock A/C mount bracket:
I will build some type of bracket from this location to the bracket coming off the engine mount
Now it was time to remove the engine mount bolt since I will be going off of this as well for a set of brackets. But the engine mount bolt on the passenger side is to long and it interferes with the Alt. So now I have to remove my belt(Gotta loosen the Power steering pump to do this), then I used more bailing wire just to hold the ALT in position, So I can remove the bolt, so I can start more bracket work! ! !
You can see that by this time Im getting frustrated.
So at this point, I just want to get everything apart so tomorrow I can start the brackets. Here is the final pic before I closed the garage and went inside to take a shower, drink a beer and post this for you all:
I like what Corey said about mounting this as high as possible. I will aim for that. But now is the time to just think about a good gameplan. I caught myself thinking of taking short cuts only because I was getting tired and frustrated. So that was the sign to STOP and call it a night. I need time to think and I'm sure I will come up with something good by tomorrow.
I am going to have to go buy a longer bolt for the passenger side motor mount so I have enough space to bolt up some brackets.
So Im off to go watch a movie and have some beer. till then.
