Just got a Hero 2. What settings are you liking best in video mode? As far as resolutions, field of view...? What's working best? Any tips? :homer:
I use the GroPro roll bar mount in my jeep to attach it to the dash bar. The mount works fine (for the past year) but the plastic construction seems flimsy. I do not expect it to have a long life, the plastic flexes when the mount is tightened down. I thinks its just a matter of time before it cracks.Cool thanks!
What about the different mounts? You using the roll cage mounts, or are the adhesive mounts fine?
Also, the case. Skeleton or waterproof? Looks like the Skeleton could expose it to dirt and sand... is the audio good enough with the othe case?
If you purchase before jan 3rd you can get Adobe Premier Elements 10.0 and Adobe Photoshop Elements 10.0 for $99 instead of the normal $159I use Adobe Premier Elements 9 to edit videos
If you want to save a few bucks you can run the Sandisk Ultra instead. Its a class 6 card but rated at the same 30MB/s as the extreme. Not sure what the difference is but so far it seems fine.If you have glitchy video you need a higher speed card. I run a SanDisk extreme 16Gb, 30Mb/s card, its cheaper to buy two of these than one 32G.
