Well, I don't....
Just swapped in a longblock into a 93 YJ four popper, ax5 tranny. The longblock was from an 87 or 88. Motor is in and running
, but the clutch is not engaging. I can row through the gears.
At first when I went to push the clutch in there was nothing there. Checked fluid and pumped it, it went down a little, couple of bubbles. Added a little fluid.
Still nothing, seemed to get a little stiffer.
Bled it from the bottom, but didn't have a clear tube. Air came out. Did it a couple more times, some times it would blow off really hard, then others not as much. Has more feel to it, but still isn't engaging.
There is one vacuum line under the hood missing cuz I lost it, the middle one on the top of the intake, nearest to the fender, it is in between the large one and the one towards the front. This have anything to do w/ it?
