1 - 20 of 25 Posts
Any body know of a relatively cheap gps that has a full screen mph? I need a speedo and that seems the easiest. I have a big one in my boat but its too damn big for a car.
Discussion Starter · #10 ·
Will the nuvi give you the speed when you are not on a "mission"?
I have he nuvi 200w..
I use it for trips, the speedo/state option posted is very useful. I have bounced mine around offroad quite a bit in the stock mount and it holds up great and stays on the mount. The display can be set to powersave or really really bright and is visible in daylight. The nuvi 200w also has a 8 hour battery life:grinpimp: Mine seems to last forever on a charge.
Mine is the Nuvi 250w, which I don't think Garmin makes anymore but it's the same display as the one pictured above, though with a slightly different housing. Not really a die hard wheeling GPS unit, but it does do ok for getting to the trail and will accept Longitude and Latitude coordinates if you get into the unit a bit.
Look at globaltop hg-100 bluetooth GPS + HUD Speedometer
Updates 5 times per sec
7-9 hr battery life
Less than $100
They've got some video's on youtube. Looks to be about 4" long
I guess it's something to consider.
1 - 20 of 25 Posts
