1 - 11 of 11 Posts
what would be the point of shift on the fly if you had to get out and lock in the hubs:shaking:
OP you have been doing the shift on the fly to much and it has gotten worn out.
Banned
It's like these. Most Tacos came with ADD. With ADD the diff is spinning all the time because the driver side axle is aways engaged and turning. When you shift the front driveshat and ADD the diff is spinning so everything can mesh up. However, if you have manual hubs and the hubs are not locked the diff is just sitting there static.
If your driving during the winter and you know there is a possability for snow along the way, you lock your hubs before you leave and leave the t-case in 2wd untill you need the 4wd (at which point your shift on the fly)
Sure all the parts in the front end are spinning but there not under power so the truck still drives as a 2wd.
I do this with my 4runner.
1 - 11 of 11 Posts
