1 - 20 of 22 Posts
If you break one the bolts then you are going to have alot more to worry about then getting it back in. I can't say I have ever heard of anybody breaking one, but if it worries you that bad then go rent a portapower and push it out. If you really have to take those bolts out cut them off and drive them out.
I agree with what was stated above. Drive it. Mine are worse and are fine (now watch they are going to break).
· Wicked Raciest !
Yep, I guess you should have!!!!:D I ran mine bent for a year, I had to replace the front spring bushings three times in a year!!!! So I fixed it!!!! You need to quit using that hanger as a "Rock Bumper"!!!!!!!!!! Chose your lines a bit better!!!!
· Premium Member
If memory serves, Booger Weldz broke one of the early style Allpro hangers.
:eek: :eek:
Thats why i build my spring hangers out of 3/8's plate and not 1/4....
You might be able to straighten that thing out.. But why? Itll only make it weaker..Id cut it off and build a new beefier hanger with gussetes..
1/4" material throughout and hasn't bent yet...
And use spring bushing sleeves! They tie each side together and make the assembly stronger.
mine looks similar to that. thanks for the idea:flipoff2: i might box the front of the hanger in. the hanger thats bent looks weak, no effense, thats why i built my own, stronger and cheaper:D
· Wicked Raciest !
Bob Williams said:
"Gently" :D knock it back into place with a 10lb sledge, weld in gussets, wheel it.
I had to wack the shit out of mine, must have been the 5 pound sledge!!!!!:D
I bent my All Pro one just like that. Seems I read they beefed them up since then but I'm not sure. I've been running mine for a while like that.
It would be cool if All Pro would kick down one of the reinforced style *hint hint* but I haven't asked them to. :D
1 - 20 of 22 Posts
