201 - 220 of 302 Posts
Guido, are you ever going to wheel it or just use it as a conversation piece:grinpimp: I dig the stripes on the hood though:eek:
Addicted to Gear Oil
Discussion Starter #204
Kinda hard to go 'wheelin' from Afghanistan :flipoff2:
There's only a few places you can legally go off road on Oahu, although they did open an off road park just before I left, and there is another spot run by Department of Land and Natural Resources that you can go with a permit. There's a local Jeep club that sponsors trail rides, when I get back I'm going to try and hook up with them.
Bravissimo Guido, be safe and come back in one piece man. Very nice work.
Discussion Starter #206
Thanks! :usa:
I got back home a week ago. It's good to be back home. The Scout fired right up after sitting on jackstands for a year.
Thanks for your service :usa:. Must feel good to fire the ol' girl up :beer:. Any plans/mods in mind for the future...?
Welcome home!!Thank you.:usa:
X2 on the Plans/projects on the Scout?
Discussion Starter #213 (Edited)
OK so I am a little behind on updates.
This is an update from September 2013 ago that I forgot to post:
My master cylinder started leaking out the bore. After a thorough search of local parts stores and even tried Rock Auto, it seem that the '78 Grand Marquis master cylinder I was using was discontinued. I ordered one from Rock Auto but when it arrived, it did not match the picture on line (two large reservoirs, disc/disc) had one large and one small reservoir (disc/drum) After numerous emails to Rock Auto and Dorman tech support I sent it back. Both said, "Oh yes it's the correct part even though it doesn't match the picture on the website" So I paid shipping both ways for the wrong part. I doubt I will ever order from Rock Auto again.
I've been pretty happy with the Grand Marquis MC, it bolted right in the stock location, 1.125" bore. Ports on the passenger side made plumbing easy.
My next choice was master cylinder for a 1970 Corvette 4 wheel disc brakes. Two large reservoirs, 1.125" (power brake) or 1" bore for manual brakes.
I opted for the 1" bore since I don't have a booster. That should give me ~25% more pressure with a slight increase in pedal travel and decrease in pedal effort. The ports are on the driver's side, so I had make 2 new lines to replumb.
I read on line that the rear port goes to the front brakes and the front port goes to the rear. So that's how I re-plumbed. WRONG!
The ports are different sizes, 1/2 up front and 9/16 on the rear port. When I bench bled the MC, I noticed the front reservoir is slightly larger and is the first to activate/move fluid. I had to rebend and reflare to swap lines. Front port goes to the front and rear port goes to the rear.
That green coated brake line from Oreilly is the DEVIL! It took forever to get a good flare. I've flared a bunch of brake lines, and this stuff kicked my ass.
I tried my new Phoenix reverse bleeder with mixed results. It seemed to work OK on the rear calipers, but the front calipers it just leaked out the bleeder threads, so I re-bled them old school with my wife pushing the pedal a some tubing and a jar. I got it all installed and bled and it feels pretty good. I like the new pedal feel, not quite as firm, I may still have an air bubble. After the first pump, the pedal firms up nicely, so I think I still have an air bubble. Hopefully I can bleed again and get a nice firm pedal.
There are a few other differences also, the mounting holes are a bit wider on the Vetter MC (Grand MArquis is~ 3.25" Vette is 3.4") so I had to pop off one of the welded nuts and enlarge the hole a bit. Also I had to lengthen the push rod ~3/16".
Discussion Starter #214 (Edited)
OK I'm a bit behind, so here's a few updates:
A few cosmetic updates, added an aluminum diamond tread door insert, I was going to originally do the whole door panel in diamond tread, but decided to stick with a few accent pieces.
One of my tailgate cables broke...so I made some new ones with some parts from the local boat shop. 3/16" stainless steel cable, stainless swivel and a snap link, added some heatshrink to protect the paint.
Discussion Starter #215 (Edited)
So...while I was working on my doors for the insert, I noticed that two of my door hinges were cracked (the barrel where the pin goes through) A while back I drove out the stock pins and replaced with stainless bolts, I'm not sure if that's why they cracked, or if they would have cracked anyway.
I was going to make my own hinges, but after I came home with $100 worth of pins, bushings, and steel, decided I would be time and money ahead to order a set of replacement lift off hinges from Jayson at Canyon Offroad. While the price may seem a bit high...it's cheaper than a stock set, saved me a bunch of time, and these hinges are super nice, big, beefy, and bolted right on.
First I had to get rid of the stock hinges, of course the top set came right out, but the bottom ones are of course stuck fast since the bolts get all the mud, salt, and road grime. After I drilled the heads out, dropped an nut down on the stub gave them a shot of the MIG welder. Spray your favorite penetrating oil on and they will come right out. Works like a champ on these old rusted bolts.
New hinges from Jayson at Canyon Offroad:
The fit on these hinges is soooo nice. I sprayed them with my favorite Rustoleum Hammered black spray paint. The tolerance on the pins is so close that I had to scrape the paint off the pins to get the hinges to fit back together and hang the door properly. :grinpimp:
Here they are installed:
Discussion Starter #216
I retired from the Army and moved back to Texas.
After a month on the boat and transport truck the Scout is back home in Texas.
Unfortunately, it fired right up to drive off the truck, then promptly died :mad3::mad3: It was very cold and wet that day, and after a month in transit, I figured my 5 year old batteries were not up for the task (even after an overnight charge and a jump pack, still would not fire up...just turn over).
I don't have any of my tools yet, just a small 3/8" drive ratchet set, a Crescent wrench, and a screw driver. So... not too much I can do. I got some new batteries. Which requires removing the front valence & grill shell...not too bad if you only have to do it every 5 years.
Still no good. :mad3: I added some diesel, changed out the CPS , charged the batteries again...did some more trouble shooting...got a new scanner (Auto Enginuity very cool) and scoured the dieselstop forum for ideas. Thanks to my wife's detective work, we finally tracked it down to a blown fuse that powers the fuel filter heater and the ECU... vroom! :bounce2::bounce:
Parked next to the wife's new Jeep.
Finally added some bling
