281 - 300 of 304 Posts
Addicted to Gear Oil
Discussion Starter · #281 ·
Finished up with 3 more coats of white base and then shot the clear. Not going to win the Concours d'Elégance anytime soon, but looks pretty good IMHO. Next up: Glass install.
That looks bloody good to me. I wouldn't be too concerned about a couple of rough spots. If it looks too pretty you never want to risk scratching it. It's a Scout, made to use and abuse I say. Awesome job, well done.
Discussion Starter · #290 · (Edited)
They are/were Ballistic Fab weld on beadlocks on H2 rims that I bought off a guy here on PBB about 10 years ago. I ran them as beadlocks as my daily driver for about 5 years, sealed with RTV and balanced with airsoft BBs. Airsoft BBs worked like a champ.
Inner ring started to cone and I got bad leaks along the welds (not between the tire and rim, but between the inner ring and the rim) so they wouldn't hold air. I tried a few ideas to seal them, none worked, so I took off the outer ring and been running them as regular rims until I can afford something else. Probably not worth the time/money/effort to try and repair them since I'd need access to or pay for someone with a big lathe and a big TIG welder/MIG with spool gun.
Discussion Starter · #291 ·
Got the back glass tinted and back in with new seals from Clester's Auto.
Discussion Starter · #293 ·
After my last wheeling trip in October, I kinda bent my winch mount a little. I did a field expedient repair (pulled off the winch and pounded the plate flat as I could get it with a BFH), but considering I had slapped it on "temporarily" ~10 years ago it held up remarkable well, even pulled and F350 out with it, fullly expecting it to come flying off.
"It's only temporary, unless it works!"~Red Green :laughing:
The original winch plate was too short to span the frame rails and only had 6 short stitch welds holding it to the bumper. I've got another 'wheeling trip coming up, so I finally decided I should get a larger winch plate.
I cut off the old winch plate and added a proper winch plate that was wide enough to span the frame rails, and has a 90* lip along the back edge for more rigidity. Even threw some fresh paint on the ol' winch.
Discussion Starter · #294 ·
Santa brought me a D60 ARB for the front, but of course my usual procrastinating self waited until the week before a wheeling trip to stuff it in, as well as finally install the high steer tie rod that I've had for 6 months.
Didn't have a case spreader and couldn't get the old carrier out with a prybar, so I wrapped a strap around it and used the winch.
All braided stainless lines and Clippard pneumatic switches for the ARBs. No electrical solenoids, all manual (except for the 1 switch for the compressor) The clear PVC lines are the vent lines for the pneumatic switches.
Of course my new high steer tie rod wanted to occupy the same real estate as my lower radiator hose, so I had to rework that.
"All Weeee Drive!"
I’ve pulled 1/2 dozen gears out using 4x4 wood blocks, bottle jack & a ratchet strap. Best part is when it pops out it hits the wood.
Registurd Abuser
Looks like a good time. How did the new tires perform?
I found that putting a box end on a ring gear bolt and rolling it up against the housing then using a big pry bar under the lowest bolt and the housing pops them right out.
Guido, I'm about to start on my 1966 Scout 800 build with HP D60's front & rear, but wondering how wide your axles are? I'd imaging full width (66-67") but narrowed up with the H2 wheels, but wanted to confirm.
Discussion Starter · #299 · (Edited)
Was going to try that, but ring gear bolts were 15/16"? 13/16"? Didn't have not a box end wrench that fit. I had a socket, but that wouldn't wedge in there properly to drive the carrier out.
Very happy with the Maxxis Razr, for such an aggressive tread, they are fairly quiet on-road and did very well off road. Threw 14oz of Airsoft BBs in when I mounted them.
Yep, full width, I did not narrow them. Front Chevy SRW D60 is ~69.5" wide WMS-WMS and the 14BFF is ~67" WMS-WMS in rear.
