1 - 9 of 9 Posts
I'm at about 3.75" and they work well. Any more than that and they'll rub the front suspension pretty bad. I had to turn out the stop screws quite a ways to keep 42's from hitting the frame ahead of the tires even after removing the radiator support body mounts from the frame.
i have a somewhat on topiuc quesiton, im confused
right now i run 16.5x12 wheels with 4.5" backspacing, i have a set of 16.5x10 double beadlocks on order, i cant figure out what backspacing to use....i want the same width i am at now. or a little wider for clearance.
i guess my question is with a 12 inch wide wheel and 10 inch wide wheel, and both having the same backspacing, would i be narrower with the 10 inch wide wheel? what b/s do i need to be the same as 12 inch wide wit 4.5 bs?
im confusing myself here
1 - 9 of 9 Posts
