1 - 7 of 7 Posts
Can anyone tell me how much their 14 long 150 sring rate HAL's saged with the weight of the front end on them? Peferably someone with a 1.6 16 valve with suck trans and t-case with no winch but i'm not picky. Would just like to get it close as I can for setting up the mounts.
erk
a 150in/lb spring will compress 1 inch for each 150 lbs added. or since there are 2 springs shareing the front load every 300 lbs would compress it an inch. guessing at a front end weight of say 1200 lbs: then 4 inches, 1500:5" etc....
i like simple math:D
Ok, I just measured and the coils are just shy of 11", like I said before with the stock 1.3 motor, tube winch bumper and warn 8000# winch.
Hope this helps.
1 - 7 of 7 Posts
