1 - 7 of 7 Posts
Do a search, this has been done here before. I bought all my stuff at the bike shop for around $8.50 and it is easy to install. Oh, and <IMG SRC="smilies/thefinger.gif" border="0"> <IMG SRC="smilies/thefinger.gif" border="0"> Newbie.
· Premium Member
Originally posted by beachtaco:
<STRONG>Where can I a hand throttle how-to? I'm interested in one for my 99 Tacoma. I know I will probably have to modify it to work.</STRONG>
I have a writeup on my hand throttle installation below:
Hand throttle install
I've got a write up on mine at www.cascadecrawlers.com in the toyota tech section. Attach cable to gas pedal arm.
Administration still hasn't got the pics up yet, but drop me a line if the text doesn't explain it right. Here's some pics.
<IMG width=207 height=392 SRC="http://www.pirate4x4.com/ubb/uploads/Hand Throttle 2.jpg">
<IMG width=547 height=442 SRC="http://www.pirate4x4.com/ubb/uploads/BarAdj.jpg">
<IMG width=324 height=480 SRC="http://www.pirate4x4.com/ubb/uploads/TriAli.jpg">
I've got a crawler in the truck now, so I moved the throttle lever back to the second lever so now it is really easy to reach and operate, even when leaning out of the truck. idle speed can be set with either barrel adjuster, or by sticking a screwdriver under the lever (if you want it really high.)
[ 10-23-2001: Message edited by: Wheelie_Pete ]
For rigs with EFI, why bother with a cable? On my 86 I just simply bypassed air pass the throttle plate. Just make sure it is metered through the air flowmeter so the mix doesn't go lean. Worked great on my truck.
Just get a manual choke conversion kit for a carbeurator. Comes with a cable, bracket, etc., and connect it with the regular throttle cable.
Broderick
1 - 7 of 7 Posts
