1 - 5 of 5 Posts
Wish it was my job!
I have a wiring gremlin on my dump trailer... intermittent short in the marker light circuit. I have not yet given up on finding it, but I've found a band aid to put on the bruise until I do:
https://www.waytekwire.com/item/46771/EATON-s-Bussmann-Series-22110-300-ATC-ATO-Circuit/
Now at least when the short pops up, I lose dash / marker lights in the truck for 3-5 seconds, instead of until I pull over and replace a fuse. I know it's not the right solution to the problem, but it has at least made the truck / trailer combo safer until I can find the damned short.
I'm also considering one inline on an aftermarket power window I'm working on, I figure it will save the motor from being hit with over current if someone holds the up / down button after the window has hit its stop.
Downside is now that finding the short isn’t a necessity, I’m going to guess it will still be like this in a year. ;)
Wish it was my job!
No, I have now finally admitted defeat in the areas of being Mr. DIY... I'm too f'ing busy. One of my guys is fairly intelligent and capable of turning a wrench. Coincidentally he is also trying to buy a house and needing extra income. So now I throw down a little more payroll, and the company trucks get maintained a lot better. This is also paying dividends on the home front since I have time to jack around with my personal vehicles, hence the thread about an automatic cutoff on the 12v constant in my dodge tow rig.
Wish it was my job!
Problem i have had like this has been loose connection inside of the 7 pin connector.
That self resetting breaker should be used for determining where the short is, and not a band aid.
I did not try digging into the 7 pin, that's a good call.
1 - 5 of 5 Posts
