1 - 9 of 9 Posts
Alright I'm trying to find a replacement for my divorced tcase. I got a nissan but that's besides the point. Anyway here's where I am at.
My t-case is flanged on the input and both outputs. The front output is in-line with the rear.
I'm doing a SAS to get rid of the ifs on it. I want another gear driven t-case. with an offset front output. So i can get either a left or a right drop axle.
the main thing is I need the main input to be a flange to bolt to my intermediate shaft I was looking at the np205. but the low range is worse then what I got now. 1.96 vs. 2.07 or something like that. Not sure if a d300 ever came with a flanged input. SOmeone told me that a suzuki samuari's tcase is flanged all the way around. That might not be bad cause you can get 8:1 crawler kit.
Any ideas would be helpful.. And no I'm not buying a different truck.
Trailzuk_Qc said:
Hi!
The Samurai t-case isn't hardcore...
Explain why not? It's gear driven not chain driven. ALot of different options. Came stock divorced.....driver drop. with 8:1 and 60's with 6.17's. I think I briggs and stratton motor would turn 40's without a problem.
alright my motor stock makes 117lbs of torque and 96 hp. I have built the motor so I'm right around maybe 150 lbs of torque and 140 hp. GUessing....I can't be more then that though.
1 - 9 of 9 Posts
