1 - 6 of 6 Posts
Sort of painted myself in a corner. 02 x model. I am converting my front axel to a ford 5 lug pattern using a Waggoneer front axel and f250/150 brakes.
I am having trouble finding a wheel that runs with the 87 mm center, 5 on 5.5 bolt pattern in 17 or possibly 18 inch sizes. i'd like to go 9-10 inch. Preferably 10.
I want to go aluminum w/o breaking the bank.
Any suggestions on brands or sources would be helpfull
thanks for your replys
I went through this a while ago.
You can either use mid 00's Dodge wheels and open the center bore, or use aftermarket lug centric wheels and lug nuts.
I ended up using steel 17x9s and they work great with 37-12.5s. They don't look bulged at all.
If your tires are 14.5 then you probably will want 10" wide wheels.
1 - 6 of 6 Posts
