1 - 5 of 5 Posts
Hey I bought a Hilux, surf, 2L, turbo, diesel ,EFI, Auto, four weeks ago It was running perfectly until last sunday, it overheated (out of the blue) and now its in the wshop blown head gasket + cracked head,nearly $4000 NZ later i'm wondering whether or not this a common problem ,and or ways to avoid it in the future,
after reading a couple of your past post there are issues with , thermostats, rads, ect any ideas would help .
Thanks
Thanks
Yes, it is a common problem to be charged a lot of money when someone else fixes your truck.
The best way to avoid it in the future is to learn to do the work yourself.
:flipoff2:
Head Gasket
Buzzbee,
Sorry to say but it looks like you have a cracked head on your 2.4L
Common problem i'm afraid.
Suggest you check out following forum on Hilux Surfs, which is you are in NZ you probably have.
www.hiluxsurf.co.uk
They have a lot of info on the head cracking problem.
Good Luck
Sewerat Bob
I have heard that alot of the Surfs that are imported from Japan have a much to small radiator for that famouse Aussie heat. I have also heard that the earlier 2L's are less prone to cracking when over heated.
1 - 5 of 5 Posts
