I've got a bit of a custom manifold on my 22r. No place for a line for the heater.
On the outlet of the heater control valve, I ran this into the passenger side front cover - there is an outlet for water here..
Photo:
Problem is - I get no coolant flow.
I assume I've tied both sides into the "high pressure" side of the water pump?
Proposed solution - drill and tap the intake manifold, under the thermostat,
Photo:
I can't find any diagrams on coolant path, but I know that water from the block goes through the heater core and somehow makes it to the head eventually... Question is - is this the right spot?
Photo:
Photo:
