1 - 4 of 4 Posts
My heater fuse in the fuse box keeps blowing. Has anyone had this happen or does anyone have an idea why it is happening. When i put a new fuse in and turn on the heater it blows almost right away! Whats going on???
You have a direct short somewhere between your heater motor and the switch or it could be the motor itself. If you have an ohm meter unplug the wire at the motor and check the wire to the switch if it is not shorted to ground check the motor. If it happens to be a bad motor you will hve an easy time replacing it but if it is the wireing or the switch you will have to trace it outand see where it is bad which can be a real PIA. <IMG SRC="smilies/usa.gif" border="0"> <IMG SRC="smilies/usa.gif" border="0"> <IMG SRC="smilies/usa.gif" border="0"> <IMG SRC="smilies/usa.gif" border="0"> <IMG SRC="smilies/usa.gif" border="0">
1 - 4 of 4 Posts
