1 - 6 of 6 Posts
Can any recommend a good after market heater/defroster. I am using a JC Whitney unit but the fan is not strong enough to defrost the windshield. I live in Massachusetts and it is COLD.
Stock unit removed due to engine swap.
Thanks,
Derek
What engine swap requires the removal of the stock heater unit?
The only other heater unit I have seen used is the JC whitney unit. Good Luck:D
I put a TBI 350 into my 1970. I have dual batteries mounted where the heater blower was. At the time I lived in CA and was not worried about the heater. I had the same heater in my 63 FJ40 with a 327 in it and it worked good in CA. Problem, MA is cold.
DEREK
I use a vintage air unit in mine it even has a defrost setting. Its compact, bolts right to the firewall and works great. I looked at the flexalite heater but it was to big to fit between the dash and the floorboard.
1 - 6 of 6 Posts
