Spent a couple hours searching for remedies, but no dice.
Going staright to the source, so here goes...
1985 FJ60 stock 2F w/HEI conversion
First junkyard dizzy imploded, left flange on, pulled guts into reluctor.
Reman dizzy, ground off flange, custom clamp, worked awesome.
Then...
Problem one...
I noticed the center contact button was really mashing down on the top of the rotor, caused the springy tab thingy to stick to the top of the rotor, losing contact until I sprung it loose. The button wears down until it isn't a problem anymore. But I'm still curious why the weird fit, are they like that stock?
Problem two(more important)...
Truck dies, replace coil (no idea why bad). Truck lives.
Truck dies, replace coil(short across wires under cap, doh!), notice problem one, replace cap/rotor. Truck lives.
Truck dies, replaced battery that was having trouble cranking the engine on cold mornings. Nada
Replaced coil. Nada
Replaced module, double check cap. Nada
Replace capacator/harness, notice and fix loose, but not disconnected, lead for dizzy relay. Truck lives for three beautiful seconds, then dies. Nada. No mas
I'll assume something gave up, burnt, fried, etc. There was no drama when it shut off, so I checked fuses connections etc. and all seems well.
Has any one had a problem like this, or am I missing something?
I really am not a elec guy so, I'm not sure what or how to check resistance/continuuity on coils, modules, capacitors, and the like.
WTF?
Help please, the doctors office where it is parked can't be too happy and this is my Daily Driver.
Thanks...
Then...
Problem one...
Replaced coil. Nada
WTF?
Thanks...
