Do you run a 3/4 bolt with on your heims?Originally posted by Bronco78:
<STRONG>3/4 x 3/4 16TPI</STRONG>
yes I use 3/4 16 TPI Grade 9 F911 fasteners at all three pointsDo you run a 3/4 bolt with on your heims?
On the D44 knuckles as well as my drop pitman arm there was pleanty. In fact the OEM taper at the largest part was already .080Just asking, I had to use a 5/8 where it goes through the arm. There just wasn't enough meat to drill it out to 3/4.
