1 - 12 of 12 Posts
DKA Motorsports
well i've finally saved up enough to get a tow rig/daily driver, aint gonna drive this bitch of a yota on the road anymore. :D now i just gotta save up for the SAS and dual cases, and the exo cage! I'm totally psyched! Feels good to know that my kidneys arent gonna get hammered anymore by the ride in the yota. now, my question is, if i got a D44 for the front end, would it be alright runnign 5.13s which d44s have, they cant hold 5.29s, right?? anyway, is it alright to run 5.13s in the front, 5.29s in the rear? am i gonna encounter any problems?
I think if they are within 10% then you are OK...
If it is mud only then I wouldn't even worry about it... or if the wheeling you do is a lot of loose stuff.
On rocks where you could be slipping and then get sudden traction all while turning - that stresses a matching drivetrain, and having mismatched gears like that would probably make bad noises that sound a lot like snappage.
ha ive ran 4.11 in front and 5.29 in back in the snow and mud. I broke the front RnP and used it as a spare. Ran all day like that didnt break a thing. Not saying i would suggest it though. For some darn reason they put toyota-t-case in 500hp cheves with 44's:eek:
tribal4krawler----I used to run 5.38 in the front and 5.29 in rear....only 1.7% diff.....the only "issue" that no one has mentioned yet is the rear is over-driving the front with that set-up....meaning the rear tire are turning a little faster than the fronts causing a slight bind-up. I also thought I noticed more push or sliding off my line when trying to go up off-camber, turn hard to the left kind of stuff.
......now if you did do the 5.13 in the front, then that's about 3% difference but it's a 'good' 3% I believe....meaning the front is turning faster than the rear and might actually respond nicely when turning on the rocks. At least when going forward.
Or you could just run a Toyota axle and not worry about it. :flipoff2:
1 - 12 of 12 Posts
