1 - 14 of 14 Posts
RH is available from several sources although not commonly stocked its a order item, about $100
the LH I think is acustom made deal, and costs alot more.
someone with a lathe should be able to cut them
Ive got a RH tap, but a buddy has a lathe at home, so I might cut one end RH and the other LH as it should be to adjust the toe in with the rod ends in place.
other wise I had planned to RH both ends and loosten one rod end to adjust toe.
I checked the ones I have and they are 7/8 14, I looked at the QA-1, NMB / NHBB, Aurora , FK, National , Heim , SKF catalogs and every one of the 7/8 rod ends is 14 TPI. Not trying to be an ass, but,,, Are you sure what you have is 7/8 18 tpi? I suppose there is one of everything somewhere out there, just never seen a 7/8 18 TPI rod end, nor can I find one in a catalog. Must be a secial order deal, or from a supplier I can not find. Good luck finding a die for it.
Originally posted by Bronco78:
<STRONG>I checked the ones I have and they are 7/8 14, I looked at the QA-1, NMB / NHBB, Aurora , FK, National , Heim , SKF catalogs and every one of the 7/8 rod ends is 14 TPI. Not trying to be an ass, but,,, Are you sure what you have is 7/8 18 tpi? I suppose there is one of everything somewhere out there, just never seen a 7/8 18 TPI rod end, nor can I find one in a catalog. Must be a secial order deal, or from a supplier I can not find. Good luck finding a die for it.</STRONG>
Look up these part #'s at your local Auto Parts dealer....They are 7/8-18.... ES2027L
and ES2026R <IMG SRC="smilies/biggrin.gif" border="0"> <IMG SRC="smilies/eek.gif" border="0"> <IMG SRC="smilies/smokin.gif" border="0"> <IMG SRC="smilies/beer.gif" border="0">
and ES2026R
Again, not saying they dont make such a thing, just new to me. What brand are those PN? What type /style are they? I've tried a few searches with the PN and get no hits?
MORE DATA, make me smarter (that aint real hard)
and ES2026R
Ok I see now, why I can not find that PN, it's a tie rod end.. NOT what was being discussed here. We were talking about rod ends.
QUOTE]mike
Member # 144
rod ends are 7/8 18 at least the GM ones I used were. [/QUOTE]
STEVECJ2A
Newbie
Member # 3515
7/8 14 is NF, but rod ends are 7/8 18. It,s not a standard thread thats why I'm haveing trouble getting one.
PN ES2027L and ES2026R are Tie rod ends, or at least on the two Car parts search pages I found, TRW and Moog
Originally posted by STEVECJ2A:
<STRONG>Dose anyone have a 7/8 18 die for cutting threads that I can borrow or rent? Haveing a hard time finding one. Thanks</STRONG>
7/8-18 is a special thread or UNS. I may have one here in Carson ... I'll check tomorrow morning and PM you.
1 - 14 of 14 Posts
