1 - 20 of 20 Posts
Sounds like it's your computer... See if you can find someone to lend you one just to try it out but I'm pretty sure that's your probleme.
thats what i figured, does anyone think it could be the camshaft position sensor, or the crank shaft position senor. i was just reading the manual and it sounds like it could even be the asd relay, whta have most of you run into? just for shits and grins i plugged my hand held scanner in and it couldn't even read the computer it said unable to read? normally i have codes for my air bag and abs wires since im missing the rear axle sensor
the computer has to see rpm before it will kick the fuel pump on, it sounds more like an ignition module, under the distributer cap held down by 2 screws, this also acts as the cam position sensor, which would explain no spark and no fuel pump run
id start with that first. iv had a few go out on me over the years. cheapest place to start
Why don't you guys learn some diagnostic procedures and actually test to find out what is wrong instead of clogging up the Dodge forum with these worthless noob posts throwing parts across the Internet at a truck whose owner can't even read.
you need to check fuel pressure i've had 2 pumps go out on 2 seperate trucks. 04.5's with the HO CTD
Discussion Starter · #11 ·
well fuck you guys, i know a lot of shit about trucks and thought you would help. fuck you homos, it aint the damn fuel pump i could always hear it come on just when the key was in run position. and now it doesn't but thatnks anyways queers
Awe, did the little illiterate crybaby get all butthurt? Drink bleach. If you are going to come on here and break the rules because you think your special, then prepare to be fucked with. So take your asshole attitude and your gay comments back where ever the fuck you came from and tell your mother to slap you for being such a whining little bitch who can't follow directions. Your stupid ass probably just doesn't know the truck is out of gas.
Discussion Starter · #13 ·
its funny how all you get upset fisrt. aww we got a newb asking questions except he sounds like he knows what hes doing. you ppl get way to pissy im fuckin around but yet everyone else is all butt hurt. you ppl spend to much time on here anyhow, dont you have lives? and for your info, i just put 5 gal in it lol. you people crack me up.
I bet your distributor had bad plugs also thats why the fuel pumps went out on your diesel truck???If you wouldnt run it out of GAS the fuel pump would last longer!!! sure glad none of you other dodge mechanics are workin on my shit.:flipoff2:I would have been better off leaving it wrecked:flipoff2:
Discussion Starter · #20 ·
when i hook my scanner up to my truck it wont even pick anything up, and i know i have some trouble codes that should pop but every time it just says unable to connect with vehicle, so sounds like my ecu is fried?
1 - 20 of 20 Posts
