1 - 20 of 29 Posts
he has a 78 chevy and wants a 4" and 35s, guys, help me to convince him he wants a 6" in the long run!
Always go more. If you get the 4 and then realize that the 6 would have been perfect you will be <IMG SRC="smilies/pissed.gif" border="0"> Just tell him to get the 6" lift because it is just correct. <IMG SRC="smilies/biggrin.gif" border="0">
Yeah I had a 88 K5 and it only had the 4 and it sucked. 6 or more is the way to go.
Oh also With my four inch lift I could clear 33's but when flexed up the front would hit. I have seen street trucks run 35's with 4 inch of lift but no offroad for them. If you want to clear 35's you need 6 inch.
Four inches and a sawzall.
Originally posted by muddogg:
<STRONG>he has a 78 chevy and wants a 4" and 35s, guys, help me to convince him he wants a 6" in the long run!</STRONG>
I did the same thing originally! I ended up pulling off the 4" and losing money on it when I sold it to buy the 6". For sure go with the 6 inch!!!!
I still had to do some minor fender trimming with 35s and a 6". Now I'm running 38s with an additional 3" body. It's AWESOME!!!
It sits up just right with the 6" and 35s!!
GO 6 INCH FOR SURE!!!!
Hmm, I have 4" of lift and run 36x14.5x15 Super Swamper TSL Radials. Can pull 1000 on a 25 degree ramp and no rubbing on the trails!
Course I did trim us some sheet metal just a tad here and there.
Depdog
I agree with the rest of these guys. If you're gonna do it, do it right the first time and save money. 6 inches is just right for 35's and if you want to go bigger, you'll have more versatility to do it... with fender trimming or a body lift.
A month after I lifted my K5 and slapped on the 35" Boggers... the truck didn't seem that big anymore.. so now I'm going bigger.
Running a 4" lift requires a 4" steering arm and extended brake lines. The only extra mods needed to jump to a 6" lift is a 2" pitman arm and a front driveshaft spacer. That's what I'm running and it works great.
Tell your buddy that he will regret going with a 4". Its not much more trouble to run a 6".
Originally posted by Black Dog:
<STRONG>Four inches and a sawzall.</STRONG>
Thats what I have and thats as high as I want to go. You can cruise up and down main street all night long on 35s with a 4" lift and no trimming. Wheel it and you will need to adjust some sheetmetal but if done properly it can look good.
[ 07-31-2001: Message edited by: chrisd ]
From a financial standpoint, never repeat a modification. Go large the first time and he won't have to pay for a 6 inch kit down the road.
I talked myself into a 4" lift instead of 6". I ended up adding (GASP!) a 3" body lift when I decided 35"s weren't large enough.
If you are SURE you are going to keep 35" tires FOREVER, 4" will be great, and a minor amt of trimming will keep them from rubbing.
If there is any chance of going to bigger tires, get the 6".
a 6 is the only way to go b/c once you start going up you will want to keep going <IMG SRC="smilies/scary.gif" border="0">
Originally posted by MUDDTOY:
<STRONG>a 6 is the only way to go b/c once you start going up you will want to keep going <IMG SRC="smilies/scary.gif" border="0"></STRONG>
Let me be the first to welcome you new guy, but lose the Thornbird line in your sig before the rest catch it.
<IMG SRC="smilies/eek.gif" border="0"> <IMG SRC="smilies/eek.gif" border="0"> <IMG SRC="smilies/eek.gif" border="0"> <IMG SRC="smilies/laughing.gif" border="0">
Go with the 4". I've got a 6" w/ 35's, there is no way the blazer weighs enough to compress thoughs springs. They look like big U's. I'm looking for 4" fronts and some stock rears, so I can lower it and put the 39.5's on.
Just cut it.
[email protected]
Definately 4" and sawzall. 6" is ok, no more than that though...you start getting too high up there. Remember, the lower CG the better. I'm running 36" Swamps and 4" lift. Soon to be 38" to 40" Swamps, same lift....sawzall is a good friend of mine
<IMG SRC="smilies/biggrin.gif" border="0"> <IMG SRC="smilies/biggrin.gif" border="0">
Boss
I got a four inch lift and 35's and with a little creative fender trimming nothing hits and I can stuff the tires into the wheel wells big time...
A buddy has a six inch lift and can't get the same flex that I can with it.. the more lift you do the less the springs will compress...
you can get softer springs but then you'll be all over the road if it's a daily driver with all the sway you will have..
A lot of how big you want is what kind of 4 wheeling your going to do.. if he's going to be doing trails and rocks then the lower lift I feel would do him better.. if you need clearance for the mud pits then go big and tall..
everyone has a different idea of how big and high they want there truck..
individuality makes the hobby fun and unique..
Just my 2ct's
6" and 35s look/work good...on the STREET.
On the trail, its too little tire and too much lift.
BTW, isn't the biggest Thornbird a 35? (says 38 in sig)
Pete
Four inch gets my vote. 35s will fit with trimming. The bigger the lift, the stiffer the springs.
For six years I wheeled a 72 Blazer with 35x15.50 SX's. Had a 2.5" susp and 2" body. Allowed me to keep nice soft springs and a lower center of gravity than just a straight 4" spring lift.
1 - 20 of 29 Posts
