1 - 19 of 19 Posts
I am midway into doing a SAS on a 2000 Silverado 1500 NBS with a corp 10bolt front which had the axle tubes pressed out, and the sides swapped to make it a drivers side drop, similar to another forum member.
Anyways, the problem now is that the leaf spring pack is a custom pack and with crossover steering the drag link will hit the leaf springs, whats the best way to solve that problem ?
The leaf springs consist of stock 52s (were too soft and ran in negative arch), plus a couple leafs from a 97 OBS rear leaf pack.
Below is a picture that was taking with everything tac'd in. If there is no way of this working then just means I get to start the search for a D60 sooner.
blatant asshole
Bent link t steering or tall cross over arm and straight link over the spring. Oil pan and steering arm dictates what you will need
Discussion Starter #4
10-4. I got a bent drag link for temporary and it's attached to the passenger tie rod end, like a stock Ford setup. One problem that happens with that setup is when turning to the right it pushes the tie rod bar downward rather then move the tire. I ordered a drop pitman arm to see if that helps.
Question, if I remove the overload is there a way to regain the height that is lost when removing it? With the overload it's sitting leveled with the rear.
I had a welder look at it and he was against everything with it. I know I'm switching to a d60 sometime, but for now I'd like to get this working and to be able to drive on the road.
blatant asshole
Cut the overload so that it's only about 6" long.
The offset seems pretty standard, let's see the dog leg in the drag link. A standard 4" bend should work that steering pretty well.
Correct me if I'm wrong.
I think D44 knuckles will bolt right up on 10-bolt front axle. So how about have the passenger side knuckle machined or get aftermarket knuckle for high steer arm for the drag link?
Rolling Mod
Yes. But he looks to need a spacer or a jogged steering arm.
Discussion Starter #8 (Edited)
Correct, the leaf springs get in the way with a crossover steering setup. So the setup of going to the tie rod bar will work for steering ? I drive the truck maybe 1000 miles a year (if I am lucky). The way I had it for temporary to move the truck (clean up after cutting IFS brackets out) the steering was pushing the tie rod bar downward, rather then moving left to right.
Get Off My Lawn
Ditch the 52" pack all together. Get a properly made spring set that will hold the weight with more arch without all the additional leafs.
Call up U-joints Off Road and talk to Chris. For about $600 they can build you the exact springs you need that won't be so damn thick and you can run standard high steer with a Sky or Parts Mike thick arm. There are plenty of machine shops who will cut and drill your stock knuckle for the arms as well.
Ditch the 52" pack all together. Get a properly made spring set that will hold the weight with more arch without all the additional leafs. Call up U-joints off road. For about $600 they can build you the exact springs you need that won't be so damn thick and you can run standard high steer with a parts mike thick arm. There are plenty of machine shops who will cut and drill your stock knuckle for the arms as well.
That and check your caster. I've seen a few rigs that would not clear high steer because they had way fawked off caster angles.
Discussion Starter #14
thanks for the info. I had a shop cut and turn the C's a couple degrees and made sure the caster was in spec. I checked with my angle finder and it was good.
Discussion Starter #16 (Edited)
PERFECT !! Thank You for the link. I didn't find that when I was searching for new knuckles. Looks like I will be placing an order next week for one.
One more question - for my shocks there currently are none on the front, so I was thinking of running them like Ford did and make the mounts on the leaf spring plate, suggestions on this, or should I run the shocks to the axle ? I would like to run dual shocks on both sides too.
Don't really need dual shocks. Get ones that are valved for your application. Off Road Design specializes in these trucks give them a shout. They also make springs and steering for this exact application. Good lick with your project looks good!
Discussion Starter #18
Thanks. First time I have done something this extreme. I have done engine and transmission swaps no problem. I will make sure to get shocks that are valved correctly.
I already have an idea for my next project, I think my next project might be to convert a Chevy Dana60 to drivers side drop. They are more common then a high pinion d60 in my area, plus would be interesting to do. I know its been done before, but I enjoy doing work like this.
Discussion Starter #19
well I am canning this front axle. I picked up a 70s Dana 60 HP front axle ($200) and a Sterling 10.5" rear axle (free) that I will be swapping in instead. I will make a new thread with lots of pictures.
1 - 19 of 19 Posts
