1 - 12 of 12 Posts
22re, 6k on a rebuild, doa 270, brand new head w/oversized valves, LCE header.
It smokes like hell on take off after idling at a stop for any length of time. If I hold the idle at about 1200 rpm, I get no smoke at all. I'm figuring my rings didn't seat, but wondering why it doesn't smoke when idled high. Should that give me any insight into the problem? Any ideas?
1989 4Runner
smoking problem
Have you tried the patch?:flipoff2:
Discussion Starter #5
steveh said:
What color smoke?
Sorry, I should have said. Its grey ish black. I'm not too sure since Im color blind. Could be blueish too. I'm not getting any rich codes.
Gotta love sucking with colors!;)
I didnt really think it was a fuel issue, EFI fixes itself in way too many places.
Since it only does it at idle, I'd have to agree with Valve guides... which is what I think Slowerthanu meant by valve stems (those things in your tires :flipoff2: )
They cant push out too much oil, and if the valve doesnt stay open as long (in seconds) at higher RPMs, it probably wont let as much oil in, if it were rings, I'd think it would do it all the time? And once it's hit higher RPM's, its probably burned it all off by then, and after idling, its probably been collecting in the head.
Make sense? Or is the reason my ass hurts because im pulling too much stuff out? :D
Dave
Discussion Starter #8
Dave
Theoretically it makes sense. I wanted to see if anyone had a problem similar to mine
have you done a compression test and a leakdown test yet?
any overheating recently?
Make sense? Or is the reason my ass hurts because im pulling too much stuff out? :D Makes sense to me, I think that theory woul be worth checking into.
Discussion Starter #12
No overheating
Comp: 170, 170, 170, 190
So I'm figuring that whether its seals or rings its that last cyl and the carbon buildup is upping the comp.
I havent done a leakdown. My compression is good. Would the leakdown tell me anything about my oil rings or valve seals?
1 - 12 of 12 Posts
